Sprayable Granite
June 2, 2005
Maxguard CG-SG-0010 is a sprayable, gel coat with excellent color and clarity for bold granite-special effects.
The coating resists sagging and air release, has passed the ANSI-124.3 standard, and can be used with both premix and dry hopper systems. It is, however, not recommended for culturedmarble applications. For these applications, the company recommends using Maxguard Series CG-44 and CG-40.
Composite Polymers, Ashland Specialty Chemical Co.
5200 Blazer Pkwy.
Dublin, OH 43017
(614) 790-4191
www.ashchem.com/ascc/compoly/
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
