Four-Channel Displays
Feb. 22, 2007
Four-channel DS-2100 and DS-2100 WiFi displays provide a convenient way to visually read load data.
The devices accept input from up to four CS Series load sensors and can digitize analog signals using 21-bit ADCs. They also sum loads from all connected sensors, let operators tare values from set preloads, and display calibrated loads at 0.1-lb increments to 999.9 lb. The DS-2100 connects to a PC through the serial port. The DS-2100 WiFi version uses a virtual serial port to provide the same ASCII command set and data-output format. Both work with LoadVUE software.
Loadstar Sensors Inc.,
453 Ravendale Dr., Suite F, Mountain View, CA 94043,
(650) 938-4282,
loadstarsensors.com
