The heater’s frame is heat-resistant, heavy-gauge aluminized steel. The units’ radiant surface, constructed with a process that uses bonded hightemperature quartz ceramic cloth, permits a maximum operating temperature of 870°C (1,600°F) with a quick response time. A precision iron/chromium/ aluminum resistance coil provides uniform emission over the entire heating surface. High-temperature insulation prevents heat loss and stainless-steel terminals provide easy power connection.
Omega Engineering Inc.
One Omega Dr.
Stamford, CT 06907
(203) 359-1660
omega.com
Jan. 10, 2025
Jan. 10, 2025
