The device generates a 2-bit digital output that measures the magnitude and direction of the shaft or knob rotation. With the addition of an integrated pushbutton, the encoder can scroll through a list or menu to select desired functions. The encoder's optically coupled switching reportedly lets it surpass 1 million rotational cycles. The device is terminated with a 4-in. cable/connector assembly.
Grayhill Inc., 561 Hillgrove Ave., La Grange, IL 60525, (708) 354-1040, grayhill.com
Jan. 10, 2025
Jan. 10, 2025
