The new capless direct-fill system calls for bonding the funnel to the fuel pipe, providing a tighter, durable seal that prevents fuel vapors from leaking. The single-component adhesive requires no mixing and has excellent thermal stability, corrosion resistance, and gap-filling properties. Because it is heat activated, working time at room temperature is unlimited. At 275°F, fixture time is 1 to 3 min with functional cure in 30 to 40 min.
Devcon, 30 Endicott St., Danvers, MA 01923, (978) 777-1100, devcon.com
Dec. 23, 2024
Dec. 23, 2024
