These give it a throughput of up to 320 Mbytes/sec for a total bandwidth of 640 Mbps. There is no bottleneck because the front side of LSI's 53C1030 supports a PCIX bus interface with a maximum transfer rate of 1,066 Mbps. The 53C1030 uses ARM technology and LSI's Fusion-Message Passing Technology to offload processing from the system's CPU and provides an open-programming interface for developers. Software drivers are available for Windows NT/2000, Linux, and Solaris. The PMCX-SCSI's two Ultra320 ports are accessible from the front panel via a dual VHDCI connector configuration.
Dynatem Inc.,
23263 Madero, Suite C, Mission Viejo, CA 92691,
(949) 855-3235, www.dynatem.com
Aug. 29, 2024
Aug. 28, 2024
