Designed for use when the placement or distance of a sensor limits its visibility, the device gives a bright, easy-tosee, two-color indicator light that mimics the sensor indicators, providing clear, visual status of the sensor. Compatible with all sensor types and brands, the EZ-Light integrates into new and existing applications with a Y splitter cable. The device works with all makes of photoelectric, proximity, ultrasonic and other sensors. EZ-Lights are available in models with nickel-plated brass 18-mm barrels or thermoplastic 18 and 30-mm T-style right-angle models. They accept npn or pnp output directly from the sensor.
Banner Engineering, 9714 10th Ave. N., Minneapolis, MN 55441, (800) 809-7043, www.bannerengineering.com
Aug. 29, 2024
Aug. 28, 2024
