Drive module
March 16, 2011
The new variation of ACOPOSmicro drive offers support for servomotors by letting users combine different drive types.
The new variation of ACOPOSmicro drive offers support for servomotors by letting users combine different drive types. The flexible drive architecture lets companies change from a stepper motor to a servo and vice versa. It supports up to two axes with performance levels of 500 W each on one module and requires a base surface of less than 50 cm2/axis.
The ACOPOSmicro can be used in a nominal voltage range from 18 to 80 Vdc for low-power applications. State-of-theart semiconductors ensure little heat loss, eliminating the need for expensive cooling devices.
B&R Industrial Automation Corp.
1250 Northmeadow Pkwy.
S-100
Roswell, GA 30076
(770) 772-0400
www.br-automation.com
© 2011 Penton Media, Inc.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
