How to determine joint size
March 6, 1997
Block-and-pin universal joints are relatively hassle-free components, provided they’re properly sized for the job. The simplest sizing involves replacing one U-joint with another of the same type
William G. McCombe
Curtis Universal Joint Co. Inc. S
pringfield, Mass.
Block-and-pin universal joints are relatively hassle-free components, provided they’re properly sized for the job. The simplest sizing involves replacing one U-joint with another of the same type. Here, sizing is merely a matter of measuring the outside diameter of the existing joint. Measuring the shaft — which is generally equal to one-half the diameter — is another option. In either case, the inside diameter shouldn’t exceed 60% of the OD. For new applications it is necessary to consider actual operating criteria. The steps are straightforward. Designers start by determining a required torque and then select a joint that meets or exceeds the required performance level. Here are the steps:
• Multiply shaft speed (rpm) by the angle at which the joint must operate to determine the speed-angle factor.
• Select the corresponding operating use factor from the use factor table. If the result exceeds 15,000, the speed-angle factor is too severe for a block-and-pin universal joint.
• Calculate the input load Lin on the joint:
force pushing lubricants away from the bearings.
One way to avoid such problems is to use molybdenum disulfide-based lubricants, which posses excellent adhesion and retention qualities. For additional protection, an oil-resistant boot placed around the bearings encapsulates the lubricant and keeps it clean for an extended period of time.
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
Aug. 29, 2024
