Looking Back
March 3, 2009
10 YEARS AGO — MARCH 11, 1999 Handheld PC keeps on-the-go executives in touch
10 YEARS AGO — MARCH 11, 1999 Handheld PC keeps on-the-go executives in touch: The HP 660LX palmtop computer from Hewlett-Packard is the first handheld PC to come with a 56k modem and 32-Mbyte RAM, double the memory of most palmtops. Priced at about $1,000, the device gives users fast access to e-mail and the Internet, and enough memory to store files, applications, and images. The 256-color 660LX uses Windows CE operating system and has a one-year warranty.
30 YEARS AGO — MARCH 8, 1979 Service hangar slides and folds around DC-9: A triangular aluminum- clad hangar that features movable work docks suspended from a monorail has been developed by Ozark Air Lines. The 24,000-ft2 structure, designed by R&D Constructors, has a cantilevered roof that eliminates almost all support posts, freeing floor space for work areas. Work docks and air-filtration and painting equipment make the hangar a self-supporting work center. The sliding-roof and folding/ sliding doors open to let aircraft be towed in.
50 YEARS AGO — MARCH 5, 1959 Tiny timer tends missile parts: A miniaturized elapsed-time indicator contains a 1-W synchronous motor that runs on aircraft accessory current (115 V, 400 cycles), a jeweled geartrain with 180 million:1 ratio, and an internal reset mechanism. It will record up to 1,000 hr to give needed information on aircraft and missilecomponent reliability. The 1.2-oz, 1¼-in.-long timer withstands 10-g vibration at 500 cps, 15-g shock, and works in any temperature from –40 to 165°F. Produced by Elgin Micronics Div., Elgin National Watch Co., Elgin, Ill., the timer can be mass produced and is used in current weapons.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
