High-slip, low-gloss film
June 7, 2007
Dureflex X2140 is an aromatic polyether polyurethane film or sheet grade that is additive-free and specially formulated to provide high slip and low gloss without blooming.
There is nothing in the film to interfere with adhesives or inks. It resists hydrolysis and fungi and is recommended for applications that have continuous exposure to water and high humidity. The material can serve in textiles as a protective and adhesive layer, or as a stand-alone film in demanding elastic applications requiring urethane's excellent wear properties.
MAKE CONTACT
Deerfield Urethane Inc., (800) 644-0116,
www.deerfieldurethane.com
