Flat speakers get smaller
June 2, 2005
The second generation of distributed-mode actuators, the electromechanical components in flat speakers for portable devices, are now 20% smaller and up to 10 times more efficient than traditional magnet-and-coil designs.
The new DMAs from NXT plc, Huntingdon, U.K. (www.nxtsound.com/general/home.php), measure 22 7 3.5 mm and rely on piezoelectric polycrystalline ceramics. Applying a voltage changes the ceramic actuator, which generates sound when the actuator is connected to an acoustic lens. In a portable phone, for example, the DMA, which contains two ceramic actuators, attaches to the display screen, which vibrates to create sound. DMAs are typically 1.5-mm thick, weigh about 2 gm, and cost less than $2.00.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
