Watertight electrical connector resists EMI
Sept. 5, 2002
New electrical connectors from Lumberg Inc
., Midlothian, Va., have durable, threaded metal housings, giving the connectors an IP 65 watertight rating and full shielding from EMI. Available in 10 different pin configurations from up to 12 pins, the connectors are rated for 60 to 250 V and up to 5 A, Options include in-line cable-to-cable connectors, front and rear panel versions, and panel-mount PCB connectors. The connectors' circular housing ensures self-sealing alignment for reliable connections.
