Flipper-type valve meets analytical needs
April 4, 2002
A pair of new valves from Burkert Contromatic Corp., Irvine, Calif., uses flipper actuators and flexible diaphragm materials to let them handle high pressures and low internal volumes.
The low dead-volume, low-carryover valves eliminate cross contamination, making them well suited for analytical and medical applications. The valves (Type 6127/6128 and 6607/6608), with orifice sizes to 3 mm, can be configured as three-way valves with all three ports in the base, or as two-way, normally opened and normally closed valves. A stainless-steel plate insulates the actuator from the coil, preventing the coil from overheating. The flipper design, which is relatively frictionless and back-pressure tight, resists clogging and sticking, giving the valves a long, accurate, and reliable life. The valves maintain fast opening and closing times (15 to 25 msec) over fluid temperatures ranging from 0 to 236F. Operating fluid pressures can be as high as 42 psi on the Type 6607/6608 and up to 140 psi on the Type 6127/6128.
Type 6127/6128 valve use ethylene propylene diene monomer (EPDM) or fluoroelastomer diaphragms to isolate fluids from metal parts, preventing metal-to-fluid contact that can cause abrasion, contamination and corrosion. Type 6607/6608 valves, on the other hand, use perfluoroelastomer diaphragms to completely separate the actuator and fluid for high purity and easy maintenance.
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
