Low on weight, high on strength
Feb. 20, 2002
Moldite is a lightweight, highstrength thermal-set resin with a high stiffness-to-weight ratio.
Moldite is a lightweight, highstrength thermal-set resin with a high stiffness-to-weight ratio. It is an alternative to ultrahigh-strength steel and aluminum. Specific gravity for most Moldite structures is less than 1. It can be formulated to exceed the tensile strength of flanking long-fiber materials including carbon, glass, or aramid fibers. Moldite's structural stability delivers fire-retardant and corrosion-resistant properties including resistance to harsh chemicals, caustics, mold, mildew, and most environmental conditions. It can also be used for energy blocking and temperature insulation. Moldite has high impact resistance, yet is highly machinable.
Venture Industries, 6555 15 Mile Rd., Sterling Heights, MI 48312, (810) 294-1500.
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
Aug. 28, 2024
