Hydraulic Products: Cartridge Valves
June 5, 2008
SVRV10-26 dual-function cartridge valves combine a normally open solenoid valve with an integral nonadjustable relief valve.
The economical and compact products are for hydraulic circuits needing both a bypass unloading function, as well as overpressure protection. The valves are rated for flow to 75 lpm (20 gpm) and pressure to 310 bar (4,500 psi). Combining two functions in a single valve makes for a smaller and lighter package and reduces the cost of manifold machining and final assembly.
HydraForce Inc., 500 Barclay Blvd.
Lincolnshire, IL 60069
(847) 793-2300
www.hydraforce.com
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
