Miniature pump for portable instruments
April 1, 2005
For portable instruments that need to pump anything from water to corrosive slurries and acids, KNF Neuberger Inc.,Trenton, N.J. (knf.com), designed a miniature diaphragm pump that is light, compact, and immune to EMI and RFI.
For portable instruments that need to pump anything from water to corrosive slurries and acids, KNF Neuberger Inc.,Trenton, N.J. (knf.com), designed a miniature diaphragm pump that is light, compact, and immune to EMI and RFI. Diaphragm pumps have no tubes to fail and deliver reliable, consistent performance. It uses a dcbrushless motor and corrosionresistant PVDF, FFPM, and PTFE materials that withstand acids, caustics, and other harsh fluids. The pump is self-priming and will run dry indefinitely. Flow rates range from 0.05 to 3 lpm. Water suction is rated at 10 ft or 85-psig head pressure.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
