Recycling plastics with magnets
July 7, 2005
Many plastics manufacturers use processes like sequential 3D blow-in molding and two-shot injection molding, but they create a lot of scrap during start-ups or due to flashing and defects.
This waste can be hand cut and sorted to salvage some of the higher-end plastic, but manual labor is expensive. As a result, most is thrown away because it is mixed with so many other resins. A new process and machine from Eriez Magnetics, Erie, Pa. (eriez.com), embeds magnetic particles in a resin, letting a machine pick it out from the other resins.
The process begins with magnetic particles called PolyMag added to the high-priced or mostvaluable resin, such as Santoprene — at a 1:99 ratio. The magnetic additive doesn't affect the resin's properties. Then, if a run of 100 parts has defects, they get ground up and sent through the PolyMag Separator. The Separator pulls out Santoprene using a magnet. Once complete, the recycled Santoprene is of high enough quality to be reused. The process saves money and gives company a cost-effective way to recycle polymers and plastics. Engineers at Eriez say that varying amounts of PolyMag can be added to several resins, letting all the resins in a device or part be separately reclaimed and reused.
June 27, 2025
June 25, 2025
June 25, 2025
