Noise levels are just 83 dBA. A 0.025-in. air-gap opening, set with a stainlesssteel shim positioned between the body and removable cap, releases a precise amount of air. Surrounding room air is pulled in to produce a wide, forceful stream of high-velocity, laminar air. Air consumption is 37 scfm at 80 psig. The nozzle comes in zinc-aluminum alloy for rugged industrial applications and Type 316 stainless steel for corrosive, pharmaceutical, and food applications.
Exair Corp.
11510 Goldcoast Dr.
Cincinnati, OH 45249
(800) 903-9247
exair.com/2hpsan.htm
Safety Products Overview
Dec. 20, 2024
