Segmented Bearings At Work
April 20, 2000
In the graphics on the far right, a cross section of a linear guide for high-precision pick-and-place applications shows how two segments (instead of four complete bearings) support the carriage.
In the graphics on the far right, a cross section of a linear guide for high-precision pick-and-place applications shows how two segments (instead of four complete bearings) support the carriage. The bearings provide backlash-free slide assembly without sacrificing load capacity or smoothness in the aluminum slides.
In the adjacent photo, a segmented bearing acts as a rack-support mechanism for a power and manual-steering gear. The self-aligning bearing, which has roll, pitch, and yaw capabilities, supports the steering rack against pressure from the pinion and eliminates stick/slip. The bearing has a load capacity exceeding 500 lb for 2 million in. of travel and operates at temperatures up to 500°F. The design is said to reduce friction by as much as 100 times compared to plain bushings, thus increasing steering sensitivity and lowering power requirements.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
