Product Spotlight: Worm-Gear Speed Reducer
March 6, 2008
The housing, motor flange, and carrier of the 700 Series worm-gear speed reducer are constructed of 315-stainless steel to provide maximum corrosion resistance for caustic washdown environments.
The input worm and shaft are made from highstrength case-hardened alloy steel. To prevent particle accumulation and fluid from pooling on or under the unit, the reducer has a rounded housing design, plastic hardware covers, and two-piece mounting base. A large internal oil reservoir is filled with H1 foodgrade lubricant (Klubersynth UH 1 6-460) and sealed for life.
Boston Gear
14 Hayward St.
Quincy, MA 02171
(888) 999-9860
bostongear.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
