Pneumatic Vacuum Pumps
March 23, 2000
The L Series of pneumatically driven vacuum pumps provide 13 to 32 scfm and handle high leakage rates typical in carton-handling applications.
The L Series of pneumatically driven vacuum pumps provide 13 to 32 scfm and handle high leakage rates typical in carton-handling applications. The pumps from Piab Vacuum Products, Rockland, Mass., feature an aluminum connection plate for durability and a PPS composite body that weighs 1.43 to 1.80 lb. With only four bolts to remove, body assembly and disassembly are straightforward.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
