Shock absorbing rail slides
Aug. 22, 2001
With twice the thrust of a single-bore cylinder, the STP linear motion slide series have internal and external shock pads to eliminate metal-to-metal contact.
With twice the thrust of a single-bore cylinder, the STP linear motion slide series have internal and external shock pads to eliminate metal-to-metal contact. The pads reduce noise and endof-travel impact forces. Travel adjustments with shock pads can be made from the back of the slide without increasing the overall package width. Shock absorbers and travel adjustments on retract eliminate the pitch and yaw moments usually associated with externally mounted shocks and travel adjustments. Stainless-steel fasteners provide corrosion resistance, and modular mounting kits connect similar sized slides within the series without the need for transition plates. They come in three bore sizes and three travel lengths with optional travel adjustments.
PHD Inc., Box 9070, Fort Wayne, IN 46899, (219) 747-6151.
In the rapidly evolving landscape of industrial manufacturing, reliability, productivity, and worker safety take precedence. However, traditional connectivity approaches often...
June 6, 2025
Amidst the rapid evolution of electronics manufacturing, reliability, productivity, and worker safety remain paramount concerns. Yet, traditional connectivity methods often falter...
June 6, 2025
While many within the industrial manufacturing sector grasp the importance of smart manufacturing for optimizing processes, boosting productivity, and future-proofing operations...
June 6, 2025
For electronics manufacturers grappling with formidable challenges, navigating the path to success requires adapting to the dynamic landscape of the industry. How can electronics...
