The stage can travel 600 mm at up to 300 mm/sec. A hard-coated aluminum cover and vertically oriented seals protect the stage and bearing surfaces from debris. The unit includes a NEMA-23 motor flange-mounting interface. A brushless rotary motor is optional. Other options include English and metric bolt-pattern tabletops, a stage-mounted brake, and a foldback kit for use in small spaces.
Aerotech, Inc.
101 Zeta Dr.
Pittsburgh, PA 15238
(412) 963-7470
aerotech.com
Safety Products Overview
Dec. 20, 2024
