Toothed belt runs rodless cylinder
March 4, 2004
A rodless cylinder from Airtec Pneumatics uses a patented cylinder tube with two chambers to minimize leakage and improve flexural and torsional stiffness.
A rodless cylinder from Airtec Pneumatics, Addison, Ill. (www.airtec.se), uses a patented cylinder tube with two chambers to minimize leakage and improve flexural and torsional stiffness. Inside, a toothed belt turns a pulley that moves the shaft with no slippage. Common driveshafts can link and synchronously operate several cylinders. The cylinders can also be supplied with a brake mounted on the drive shaft without using a transmission chain or mechanical linkage. Combining a cylinder with a brake and encoder results in an inexpensive positioning system. Cylinder rods are available in 25 and 40-mm diameters.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
