Rugged Power Supplies
May 17, 2000
The UltraFlex Series of 400 and 600-W power supplies are ruggedly constructed for medical applications including ultrasound, blood analyzers, CAT scanners, and X-ray and MRI equipment.
The 2.5 5 10-in. units feature universal input with harmonic correction. System interfaces and a range of signaling options are available such as ac-power or module-fail notification, global and module inhibit, and active-current share. Up to 10 fully regulated, independent outputs can be used as positive or negative polarities. Users can select from 2 V to 48-Vdc output modules to power logic, analog, or ancillary-circuit combinations.
Lambda Electronics Inc.,
515 Broad Hollow Rd., Melville, NY 11747, (619) 575-4400.
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
