The new valves integrate into custom manifold blocks or circuits that combine multiple cartridge valves in a common block. The valves are suited for rugged off-highway, windpower, and steel-mill environments, and can replace other manual valves including pull/push-to-shift, threeposition, four-way, tandem center, mobile sectional, and manually operated industrial models. They come in open and closed-center configurations, and a motor-spool, open-center version lets a motor freewheel when the valve is centered. Motor spools can also be used for directional control of cylinders.
Eaton Corp., Hydraulics Operations
14615 Lone Oak Rd., Eden Prairie, MN 55426
(952) 294-7992
hydraulics.eaton.com
Dec. 23, 2024
Dec. 23, 2024
