The bearings are formed by stacking “petal-shaped” laminated aluminum-silicon alloy plates. Housed in a stainless-steel case with a polyurea-thickened grease containing antioxidant and anticorrosion additives, the inner faces of the plates act as the bore of the assembled bearing. As the shaft rotates, fluid between the shaft guide and the shaft generates pressure as a result of this “squeeze effect” a phenomenon of generating pressure to a lubricating membrane in a fluid lubrication when wall faces are close to each other.
Stock Drive Products
2101 Jericho Turnpike, Box 5416
New Hyde Park, NY 11042
(516) 328-3300
sdp-si.com
Aug. 29, 2024
Aug. 28, 2024
