Two body styles pico and nano support a range of mounting options. The sensor is programmed through easy-to-use pushbuttons and its menu may be inverted for programming flexibility. The sensors provide two pressure ranges: 29.5 to 0-in.-Hg and 0 to 145-psi, with 3% accuracy. Two pnp switch points and an integrated M8 connector let the sensor be used in many industries.
Turck Inc.
3000 Campus Dr.
Plymouth, MN 55441
(800) 544-7769
turck.com
