Blind - threaded inserts simplify assembly
How do you attach a component to the outside of large, thin-walled enclosure with a screw?
Aug. 8, 2002
Blind-threaded inserts simplify assembly
One method is to use blind-threaded inserts that can be installed without access to the backside of the panel. Atlas Engineering, Kent, Ohio, makes a variety of such fasteners. Each is installed with a special pneumatic or pneumatic/hydraulic tool, which puts the insert into a properly sized hole, draws the fastener in, and then compresses the unthreaded portion of the insert wall. The insert bulges and clamps against the panel. The inserts are suitable for painted or unfinished panels and can be placed near edges.
