Product Spotlight: Parallel-Shaft/Helical-Bevel Gearboxes
March 6, 2008
The HDP parallel-shaft and HDO right-angle heavy-duty gearboxes handle applications with torque ratings to 640,000 lb-in.
Designed using finite-element analysis and multibody simulations, the gearboxes feature structural rigidity and gear geometry for optimized load capacity and gear/bearing life. Structural simulations based on boundary-element-method analysis helped minimize noise and vibration levels.
Bonfiglioli USA
3541 Hargrave Dr.
Hebron, KY 41048
(859) 334-3333
bonfiglioliusa.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
