SAE Port Plugs
June 5, 2008
Port plugs manufactured to SAE J514 Standards are suited for sealing threaded holes and ports.
The carbonsteel plugs have a nominal OD of 0.125 to 2.0 in. with thread sizes from 5/16-24 to 2-12. Hex head, metric, and specialty plugs are available on request, as well as a wide range of O-ring seal materials. The plugs’ environmentally “friendly” trivalent-chromate plating helps protect against corrosion.
Sherex
400 Riverwalk Pkwy.
Suite 600
Tonawanda, NY 14150
(866) 374-3739
sherex.com
