Plug-In Air Valve Island
March 23, 2000
Solstar air-valve islands use a plug-in system of electrical connections to reduce machine downtime.
Solstar air-valve islands use a plug-in system of electrical connections to reduce machine downtime. The systems allow small pilot valves to be quickly assembled onto a DIN rail-mounted interface valve island with transparent automatic addressing up to 16 valves. Solstar valves from Parker Hannifin Corp., Pneumatic Div., Richland, Mich., are recommended for piloting process-control valves, handling vacuum, or controlling small single-acting actuators for automation. The valves have a flow rating of 0.05 Cv. Solstar valve islands are connected to a PLC with subD25, 19-pin-round, or cable-gland connectors. With IP-65 protection on electrical connections, the islands can mount close to valves and actuators in industrial environments.
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
