Freedom from friction
May 8, 2002
By KEVIN McCARTHY Chief Technology Officer Danaher Precision Systems Salem, N.
By KEVIN McCARTHY
Salem, N.H.
Edited by Leland E. Teschler
The advantages of air bearings are well known among those working in motion control. These devices are most noted for providing a means of movement without the ill effects of friction. The benefits they provide come in handy when realizing the nanometer-scale resolution that typifies the assembly of photonics devices such as lasers and fiber-optic pigtails.
However, there are subtleties that are not widely appreciated when it comes to the numerous small moves in photonic alignment. These subtleties have an impact on how air bearings are deployed. They also illustrate why conventional bearing systems are likely to fall short in providing such small moves.
It is interesting to compare the approach used to realize nanometer-scale moves with that for large moves. Positioning systems generally "profile" such moves, with velocity carefully shaped as a function of time so as to minimize higher derivatives and avoid exciting system resonances. The resulting graph of velocity versus time is the familiar trapezoidal move curve where velocity ramps up to some level and holds steady for a specified time, then ramps down to zero at the end of the move.
As it happens, such careful move profiling is of no utility whatsoever for the numerous small (under 100 micron) moves typical of photonic alignment. In this case, the overall energy is small and the servoloop itself is a perfectly adequate trajectory shaper. The position servoloop functions as a low pass filter. The position command can be a simple step function; At time t = 0, we simply command the position loop to be at the destination. Despite the discontinuity of the step command, the actual stage motion follows a smooth curve.
The goal, of course, is to minimize the move and settle time so as to make as many small moves per second as possible. We may also impose fairly tight values on the settling tolerance. A "move and settle time" is meaningless without a definition of the settling window, which is the acceptable difference between the target position and the actual position. In cutting-edge photonic alignment, this settling window may be as small as 10 nm.
It is interesting to graph the following error, the difference between commanded and actual position, for such a system. It is zero prior to the move, then jumps to equal the move size at t = 0 because the stage cannot respond instantly to the step command. It eventually decays back to zero. A key performance issue is this decay or settling time. It relates to servo bandwidth.
Predicting dynamic response
Consider the case where the position loop receives commands in the form of small-amplitude sine waves. A plot of position-loop response versus the frequency of the sine wave will be flat from dc out to some frequency where it will peak slightly (if the loop is properly tuned). It will then decline at a rate of f -2.
The point at which the amplitude has fallen by 3 dB is termed the system servo bandwidth. It corresponds to the point where there is a 90 phase relationship between the command and the response. It is also the most important parameter in predicting the dynamic response.
The goal, normally, is to maximize servo bandwidth. Doing so brings the highest rejection of outside perturbations and provides highest dynamic performance. There are a number of factors that can limit servo bandwidth, but the phase lag from the first structural resonance usually sets the practical limit. Attempts to boost servo bandwidth beyond this limit turns the positioner into an oscillator.
The natural form for the servo bandwidth is 0, expressed in radians/sec, but the more familiar term for servo bandwidth is f0 expressed in Hz. A conservative value for the realistic servo bandwidth of either air or mechanical bearing stages is about 50 Hz.
The lack of friction acting on airbearing stages make them easy to model mathematically, and the fidelity of the models to real-world results is quite good.
A detailed model for the decay of following error after a step move is beyond the scope of a magazine article. Nevertheless, it resembles a simple exponential decay whose time constant is a direct function of the servo bandwidth. Lack of friction in the stage means the integrator term can be zero or small. The time constant is then determined by the servoloop proportional term (assuming, of course, that the derivative term has been set to provide adequate damping).
The proportional time constant for this decay is ( 0)-1 or (2 f0)-1. For a typical servo bandwidth of 50 Hz, this is about 3.2 msec. The time behavior of the following error, starting with a step function equal to the move size is
where E = following error, X = move size, and = the time constant (2 f0)-1. Accordingly, the following error drops by a factor of e (2.718) every . If we permit a "close counts" approximation, the following error will fall by a factor of three every 3 msec.
In the case of a typical 10-micron move, this means following error drops from 10 microns to within 10 nm after a mere 18 msec. Viewed from another perspective, it is possible to make 50 such 10-micron moves every second, settling to within 10 nm. The real world being what it is a more realistic settling window with moderate cost encoders would be below 20 nm, still better than any other positioning technology.
Proportional-term failure
For small moves, friction is the dominant problem plaguing conventional stages. This leads to the important point that the proportional term in a PID (proportional integral differential) control loop is of no use whatsoever for small moves with this class of stage. This becomes obvious by considering that proportional term of a servoloop produces a force (or torque in a rotary system) linearly proportional to the error. For example, if 1,000 counts of position error produces 100 N of force, 500 counts of error produces 50 N, and so on.
In the graph of position error versus applied force, the slope of the proportional term represents servo stiffness, usually in Newtons-per-meter. It is readily calculated from
where S = stiffness, m = mass, kg, and 0 = servo bandwidth, radians/sec. Friction is a constant force. A problem arises, however, when the force due to the proportional term is less than or equal to the frictional force. Say, for example, the stage is 50 microns from the target. The proportional term responds with 5 N of force. If the frictional force is 6 N, nothing happens. The point at which the proportional term fails is called the friction boundary. If the proportional term were the only one in the servoloop filter, the following error would remain trapped at this level, never reaching the target position.
Put another way, there is no motion if the restoring force written to the output d/a converters is less than system friction. This is true regardless of how high the sample rate might be.
The amount of position error is calculated by dividing friction by stiffness. Doubling this figure yields the error for a bidirectional motion system:
where E = error, meters; F = friction, N; m = mass, kg; and f0 = servo bandwidth, Hz. In a typical case with 2 N of friction, a 1-kg moving mass, and a servo bandwidth of 50 Hz, the value for the friction boundary is 81 microns. This value is typical of mechanical bearing stages. Friction would be a little larger for a recirculating bearing stage and a little less for a crossed roller stage. But errors on the order of 80 microns are large compared to the dimensions involved in photonic alignment.
It is interesting to run the same analysis for a leadscrew stage. The angular error for a leadscrew is
where E = error, m; L = screw lead (advance/rev), m; T = torque, N-m; J = total rotary moment of inertia, kg-m2;
and f0 = servo bandwidth, Hz. The motor rotor dominates the rotary inertia. Other significant contributors are the leadscrew and (coming in a distant third) the reflected payload inertia.
Typical values for screw lead (0.002 m), leadscrew torque (0.05 N-m), total rotary inertia (5 10-5 kg-m2), and servo bandwidth (50 Hz) yield a friction boundary of 13 microns. This is still too large to be useful in photonic alignment tasks.
The I in PID
It is also interesting to examine whether the integral or differential terms in the typical servocontroller PID loop can cure the friction boundary problem. The differential term supplies a force or torque which opposes motion and which is proportional to velocity. It provides damping necessary to ensure stability. But it is of no use once motion has ceased at the friction boundary. Moreover, it generates a force with the wrong sign to be of any help.
If conventional stages with friction get at all close to final position, they must turn to the integrator term. It slowly sums the errors of past samples to produce a growing output command that will eventually get the system to zero steady state position error.
Unfortunately the introduction of the integrator term degrades stability. For stable systems, the integrator time constant will be five to ten times that of the time constant of the proportional term. So with a system having the 3.2 msec decay time of the earlier example, the integrator time constant would be on the order of 25 msec.
Similarly, the time needed for the 10-micron move in the example of the frictionless air bearing would expand from 18 msec to about 150 msec if carried out using a conventional stage with friction. Tricks such as gain scheduling, acceleration feed forward, friction bias, and backlash compensation can mitigate the problem somewhat. Nevertheless, the resulting systems have a limited performance as well as substantially less throughput and precision.
In contrast, frictionless air-bearing stages can follow the rapid exponential decay of the proportional servo down into the noise. The ultimate limits on performance for these stages are set only by encoder resolution, amplifier linearity, and external vibration.
Trapezoidal move profiles are fine for larger distances but unnecessary for handling positioning tasks below about 100 microns. In the alignment of photonic components, the overall energy is quite small and the servoloop itself is a perfectly adequate trajectory shaper. Position commands in this case can be a simple step function. A plot of the difference between commanded and actual position (i.e., following error) has the character of an exponential decay.
Adding an integrator to the control of a mechanical stage yields a system that slowly settles to a small following error. Stages with friction compromise on either high throughput/low accuracy or low throughput/high accuracy.
A graph of position error and applied force illustrates the deadband that results when force generated as a result of the proportional term is less than that of friction. The proportional term alone is not sufficient to drive the system to zero following error.
"Peak" performance with air-bearing stages
Air-bearing stages work with a Photonic processor in the setup illustrated here, from Danaher Precision Systems. The Photonic Processor carries a laser light source, optical power meter, and a Gradient Engine board. The Gradient Engine works with a motion control board to implement synchronized dither motion for aligning two fiber-optic devices.
Dual-axis, submicron dither motion together with synchronous demodulation of the optical power signal yields a "servo-topeak" technique that's faster and more accurate than search or algorithm-based peakfind methods. The Danaher system is also the only one able to produce the sort of nanometer-scale dither movements necessary for synchronous alignment without resorting to a piezo actuator. Air-bearing stages provide all the necessary positioning.
Optomechanical-analysis software
TracePro 2.4 software for illumination and optomechanical analysis reduces product-development time. One version models thousands or millions of repetitive surfaces used in display and lighting products to model prismatic films, lenslet and fresnel lens arrays, and scattering dot patterns. Importance-target visualization, included in all editions, shows single or multiple importance targets that can be applied to surfaces and sources to boost raytrace accuracy while reducing the number of rays traced. Users can define ray color as a function of flux, implement directional ray arrows to show ray direction for split-ray components, add working coordinate systems to transform global origins, and display a local coordinate axis for each object.
Lambda Research Corp., 80 Taylor St., Littleton, MA 01460, (978) 486-0766.
Three-beam laser welder
The ETBL-Series laser welder features three fiber-optic coupled outputs. The design is based on a 30-W pulsed Nd:YAG laser. The output is split into three equal portions and delivered through optical fibers. Each laser beam has independently controlled mechanical shutter to selectively turn it on and off. In single-shot applications, each laser beam produces energy to 7 j and 10-msec pulses. Pulse-to-pulse energy stability can be better than ±2%. The system is designed to meet the needs of multiple laser beams firing simultaneously. It can be controlled from a front panel or from PC software via an RS-232 connection.
Equilasers Inc., 3350 Scott Blvd., Bldg. 5, Santa Clara, CA 95050, (408) 588-1212.
Precise needle valve for microdeposits
The 741MD-SS MicroDot needle valve dispenses extremely small, accurate amounts of epoxies, adhesives, and other fluids used in critical fiber-optic assembly. The needle sits in the hub of the dispensing tip instead of the valve body, reducing the amount of dead fluid volume between the valve seat and the substrate. This is said to shorten setup time when applying almost invisible amounts of adhesive and produces a clean, drip-free cutoff from dispensing tips with internal diameters as small as 0.004 in. The ValveMate 7000 controller regulates valve operation and adjusts valve-open time in increments of 0.1, 0.01, or 0.001 sec.
EFD Inc., Dispense Valve Systems Group, 977 Waterman Ave., East Providence, RI 02914, (888) 333-0311.
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
