Top is sloped down 20° so water runs off and no one places objects on top of enclosure. 1.5° sloped door flange promotes run-off and prevents leakage. |
Optional leg kits raise enclosure off the floor to facilitate complete washdowns and come in fixed and adjustable models to accommodate sloped floors. (Optional 1 and 6-in. stainless-steel wall standoff kits minimize contact between wall and wall-mounted enclosures while providing support). |
Bullet-style hinges lift off for easy cleaning inside and out. Door edge cutouts enable washdowns to clean hinges. Smooth #4 finish provides maximum surface run-off.Foam-in-place gasket eliminates seams and resists high-pressure washdowns. UL 4X latches provide tight seals |
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
