Compact PLC
June 1, 2000
D32LT is a compact, flexible PLC from Cutler-Hammer, Pittsburgh, that features PIC loop control, a real-time clock, two programloader ports, MODBUS support, and ladder memory.
D32LT is a compact, flexible PLC from Cutler-Hammer, Pittsburgh, that features PIC loop control, a real-time clock, two programloader ports, MODBUS support, and ladder memory. It supports from two to eight I/O modules in one system using a backplane and module structure. With 16 and 32-point digital I/O, a single system provides up to 256 digital I/O points. D32LT is available with typical I/O ports and modules including 24 Vdc, 115 Vac, and relays. Analog modules come in 0 to 10 V and 4 to 20 mA, as well as RTD and thermocouple. The 24-bit, 100-kHz high-speed counter module provides pulse outputs for simple positioning control, and the serial communications module lets users connect ASCII devices such as bar codes and printers.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
