The Quantim mass flowmeter and controller is designed for low-flow applications. It provides a direct integrated method of measuring and controlling mass flow that needs no conversion factor for use with different fluids or process conditions. Quantim delivers fluid accuracy better than 0.5%, regardless of the fluid being measured, as well as precise mass-flow measurement. It offers process flexibility, providing multivariable output for measuring temperature, flow, and density. Its through-flow path eliminates measurement error caused by clogging, which reduces downtime and maintenance.
Brooks Instrument, 407 W. Vine St., Hatfield, PA 19440, (215) 362-3669.
Jan. 10, 2025
Jan. 10, 2025
