CCTY
Articles
289588967 © Rinofelino | Dreamstime.com
Robotic arm
Why custom, integrated bearings are key to stronger, smarter joint design.
Sept. 15, 2025
Made with Adobe Express
Precision in motion control
Bearings manufacturers like CCTY are pushing beyond traditional products toward integrated, custom-engineered solutions. Heeding market challenges, manufacturers are also making...
Sept. 15, 2025
7996356 © Joanne Zhe | Dreamstime.com
Lead image
The ideal bearing solution in humanoid robots will manage varying loads and minimize energy loss. Consider these and other specifications engineers can tailor to their applications...
May 19, 2025
CCTY
In humanoid robot design, bushings are used in tight spaces where bearings can’t be used.
A breakdown of sought-after bearing types for linear and rotary motion applications, including crossed roller, flexible ball and four-point contact ball bearings.
Dec. 26, 2024
333870687 © Maksim Marchanka | Dreamstime.com
dreamstime_m_333870687
Consider key material selection factors and assembly requirements when choosing bushings for robotics applications.
Oct. 23, 2024
ID 328070821 © Olga Demina | Dreamstime.com
dreamstime_m_328070821
When designing humanoid robots, the performance of rotary actuators hinges on component precision, alignment and quality. Custom crossed roller bearings can lead to significant...
Aug. 21, 2024
CCTY
An SPB comprises three main components: outer ring, inner ring and, in self-lubricating models, a liner that resides between the two rings. Some SPBs can also be sealed on request.
Discover the key factors for choosing the perfect SPBs for your robot. Explore the pros and cons of the various types and learn best practices for assembly in linkages.
June 21, 2024
Request More Information From CCTY
