Courtesy C&J Industries
examples_of_small_part_over_molding_both_over_mold
Two-Shot Molding: The Advantages, Considerations and Real-World Applications
April 1, 2024
C&J Industries acquired a 220-ton Nissei two-shot press so they could accommodate the jobs they had been having to turn away.
The decision to invest in a 220-ton Nissei two-shot press was a strategic move made by C&J Industries, Meadville, Pa., to expand its capabilities. The selection of this press was a deliberate internal project aimed at gaining experience in this specialized process. By matching the press with its two-shot coaster, the company addressed the growing demand for products that require two-shot capabilities.
Machine Design reached out to John Hanninen, senior engineer of new business development at C&J Industries, to learn about the process, its advantages and its challenges.
*Editor’s note: Questions and responses have been edited for clarity.
Machine Design: I understand that two-shot molding is something C&J Industries has recently taken on. Can you tell me about that decision, including how the company went about selecting its 220-ton Nissei two-shot press?
John Hanninen: Over the years we have had many instances of having to turn jobs away that required two-shot capabilities. To gain experience, management decided to pursue an internal project and after searching around, it was decided a good used press would be purchased. The Nissei was selected to match up with our two-shot coaster.
Going forward we will buy a unit(s) that fits the application we are awarded. There are various options depending on the program whether we buy another two-shot press or buy a side unit that can be used on our existing presses to do two-shot molding. Two-shot molding is very dependent on the part size and shot size required for each material and matching the part to the press size required.
MD: What are the primary advantages of utilizing a two-shot injection molding process?
JH: The primary advantage is cost savings from producing a completed two-shot or two-component product every machine cycle. You can usually get better quality with better adhesion between the two resins and better matching of the second core or cavity to the first part since it stays in the mold, so the aesthetics are improved. More than one color is possible.
Secondary assembly operations or separate over-molding or insert molding of the first part can be eliminated. It also reduces handling of parts like you would have with over molding, which increases WIP and potential of part damage or contamination that you avoid with two-shot molding.
READ MORE: Five Considerations for Injection Molding Design
MD: Can you explain the key considerations to keep in mind when designing parts for a two-shot injection molding process?
JH: The upfront tooling costs for two-shot molding can be significantly more than conventional molding, so an analysis of the return on investment (ROI) would be important. Does the product require a second resin? The part design must fit within one of the several methods used for two-shot molding, so before a design is started you need to know the difference between them. Are the resins compatible? Do you need them to bond together or are you creating an assembly?  Depending on the resins you select, some resins chemically bond well together while other resins may require that mechanical bonds are designed in to better hold the two different resins together.
MD: Does the two-shot process enhance the quality and durability of the final product compared to other molding techniques? If so, how?
JH: While the final quality of a two-shot part compared to an over-molded part can be similar, the benefit comes from scrap rates and machine capacity. You may run through more parts in the over-molding process to get the same amount of quality parts that you would get with two-shot molding.
MD: Tell me about the resin materials used in two-shot injection molding, and how does the selection of materials impact the overall product design?
JH: The initial resin or first shot is usually a rigid material such as ABS, polypropylene, nylon, etc. The second resin is usually soft resin like a thermoplastic elastomer or silicone-type material. Common items like hand tools with soft grips and even toothbrushes all take advantage of the two-shot process. It can also combine two rigid resins allowing multiple-colored parts like a headlight or taillight with opaque, clear and amber or red variations all in one component.
Various resin manufacturers have developed materials specifically for two-shot molding to achieve an adhesive or chemical bond between the rigid and soft resins. Working with them would be an important step for a successful design. If two resin are needed that are not meant to chemically bond to each other, then you must design in a mechanical bond feature to be able to mold a successful part.
READ MORE: Using Injection Molding to Design a “Smart” Wheelchair Fit for Family
MD: What challenges or limitations did you encounter when implementing a two-shot molding approach? How were these overcome?
JH: Our press uses parallel injection units and a rotary machine platen. Our design had to consider the part staying on the core and rotating 180 deg. over to the other side. The product design needed to allow gate locations that are on top of each other. The shut-off surfaces between the first-shot part and the second cavity had to be considered. The second cavity must squeeze an area of the first part with enough pressure to prevent the second shot resin from leaking out creating flash. That contact area can leave a visible mark on the part that needed to be considered.
The compatibility of the two resins had some challenges due to their similar melting temperatures. They bonded well with each other, but the second resin could melt and blend into the first resin, leaving a marbled look which we did not want. Working with the resin manufacturer’s and adjusting the molding process we were able to overcome that. Another issue to keep in mind when matching a part to a two-shot press is considering barrel sizes. The amount of each resin must match the barrel size for each injection unit. This makes it hard to match multiple parts to the same press. This is a reason using a side unit with an existing press is sometimes more economical and gives you more options when trying to utilize your press capacity.
MD: Does the tooling and equipment setup differ for two-shot injection molding compared to conventional molding processes? Please explain.
JH: The tooling and equipment can be much more complex, so the setup takes longer. You are dealing with basically two molds with one side attached to a rotary platen. A robot will come in and pick and place the first shot into the second side. Does the mold have an internal core pull, a shuttle action or maybe a lift and rotate mechanism built in? Do you need air, hydraulics or servos tied into the press controls? The presses have the software built in to integrate the injection units together, so the actual injection set up is the same as a single component mold but with separate screens for each injection unit.
MD: Can you provide examples of real-world applications or case studies where this process resulted in significant improvements or innovations for your customer(s)?
JH: It has eliminated secondary assembly and bonding of the parts together, saving costs and improving the overall part quality. It has helped with part consolidation resulting in reduced cost and lead time to market.
READ MORE: Insights from MD&M West: Keynotes, Sessions and Exhibits
MD: In what ways does the two-shot injection molding process contribute to cost-efficiency and sustainability in manufacturing?
JH: Instead of paying for two separate injection molding processes run sequentially, you pay for two injection molding processes run in parallel. Each time the mold cycles you get a complete part, cutting the manufacturing process time nearly in half saving man and machine hours.
MD: Anything else you want to mention?
JH: With so many variables in design and materials it is very important if you are thinking about designing a part that could potentially be molded as a two-shot part to have your molder in design discussions from the very beginning.
May 7, 2024
May 7, 2024
May 7, 2024
