Essential Equipment for Your Filament-Based 3D Printer
March 22, 2017
These items should be in every 3D printer’s toolbox, otherwise any job may wind up taking twice as long to do, and the end results could be less than desired.
3D printers require a lot of support. They need gadgets and tools and of course, consumables. If you are using a fused deposition type of printer, the type that uses spools of filament, then there are a few essentials that you must procure for your toolbox. The items listed below are indispensable. Without them, you will be struggling and very likely using the wrong tools for the job.
The MakerGear M2—possibly the best low range printer that money can buy.
BuidlTak
BuildTak is the best all-purpose build surface that you can get. It sometimes gets a bad rap because it really holds onto prints. BuildTak does have some very real holding power. However, prints that are hard to remove are preferable to prints that remove themselves. Especially while still being printed.
The BuildTak 3D-printing build surface has strong holding power.
BuildTak is pricey, but with some care, it can be used over and over again. Even if small pieces have been torn or ripped off completely, it will still hold. Just make sure that the raft is wide enough to anchor itself past the damaged parts of the sheet.
This BuildTak layer is ugly, but it can still be printed on with no problems. Shown here is the 3D printer at my shop.
Air-Tight Containers
You will need containers to store your filament to keep it from absorbing moisture from the air. Print quality will degrade in proportion to the amount of water taken on by the filament. Unless you are burning through rolls of material very quickly, you will need to store them properly, so they don’t go to waste. Finding a truly airtight container may be difficult and expensive, so something that is very nearly airtight will do.
The 21-cup Rubbermaid container can comfortably hold a 1-kg spool of filament.
The Sterilite 19-liter gasketed storage box can hold several spools of filament.
Desiccant
To make the perfect storage environment for your filament, you need more than airtight boxes. You will also need desiccant. It will grab moisture before it gets to your precious filament and it will slowly draw any out that has already been absorbed.
Desiccant is essential for proper storage of 3D-printing filament. When the beads of desiccant eventually turn red, you can reuse them by drying them out in the oven.
Print-Removal Tools
After a print is finished, tools are typically needed to get it off of the bed. This is especially true if you already took our advice and started using BuildTak.
Painter spades like these are very effective in removing prints. When the handles break, just print another one for it.
If you get only one print-removal tool, get yourself one of these. It is thin and strong enough to work its way under any print.
Hobby Knife and Blades
A razor-sharp blade is essential for cleaning up prints. Always keep a few blade holders on hand for different blade types. Most tasks can be handled with a #2 or a #24 type blade. A #18 type blade is very useful for removing rafts from the bottoms of prints.
A few precision blade holders are essential for preparing prints. The #18 blade (shown between the blade holders) is very useful for removing rafts from prints.
Needle-Nose Pliers
Another excellent tool for cleaning up prints is a small pair of needle-nose pliers. Sometimes pliers are the only way to remove support material from a hole.  A bent tip is preferable for getting into hard-to-reach areas.
Needle-nose pliers are another essential tool for cleaning up 3D-printed parts.
A Flashlight
Sometimes it is really hard to tell how your print is doing. Especially if your printer is in an enclosure. The only way to really check if everything is going as planned is with a flashlight.
A keychain light probably won’t be bright enough. Something in the 200-lumen range will usually do the job. Don’t go crazy and get one of those 2500-lumen handheld supernovas. It’s way more than you need and you run the risk of setting your print on fire while you blind yourself with reflected light.
A flashlight is the only way to make sure that the 3D-printed parts are coming out as expected.
A Caliper
A precision measuring device is the only way to check if your parts are dimensionally accurate. You can download and print test cubes and other diagnostic models, but you still need a yardstick to compare them to.
A caliper is a necessary diagnostic tool for 3D printers.
Leaf Gauges
Before anything else can be blamed for poor print-to-bed adhesion, the nozzle gap must be accurately set. Maybe the cheapest and fastest way to measure the gap between the nozzle and the bed is with a feeler gauge. A set is inexpensive and worth keeping in your printing toolkit.
Leaf gauges are the most convenient way to accurately set your printer’s nozzle height.
Scotch-Brite Pads
As you use your printer, plastic will build up on the nozzle. This accumulation is an obstruction to quality printing, and sometimes it can begin to burn. Scotch-Brite pads work very well to clean this off.
Scotch-Brite pads work great for cleaning 3D-printer nozzles.
Cyanoacrylate Glue (aka Super Glue)
In some cases, a print just won’t come out right when printed as one piece. For these stubborn parts, a very useful technique is to break the model up into two or more interlocking pieces. These smaller sections will warp less, and can subsequently be glued together.
Sections of a 3D print can be glued together with super glue.
Left off this list are the tools that would either come with a printer, or an individual would probably already have on hand, such as a hammer, screwdrivers, and hex keys.
This list is not comprehensive. If it were, it would be four times as long and include plans for a heated printer enclosure. Rather, listed here are the tools and accessories that will make life easier for the 3D-printer operator.
Cabe Atwell
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
