Thermal management is by far the most critical aspect of LED product design as both light output and lifetime are strongly affected by LED junction temperature. CFD simulation helps manufacturers optimize the design of heat sinks and other parts of the luminaire to produce low-cost, high performance products. Diagnose thermal problems, evaluate alternative designs, and iterate rapidly to an optimal solution with the latest generation of CAD-embedded thermal and fluid simulation software. FloEFD is the ONLY computational fluid dynamics analysis tool that is truly embedded into major MCAD systems.Download Now
