Digital Wrench Can be Connected With Wi-Fi
The OPEXplus from Bosch Rexroth covers a range of torques from 3 to 800 Nm.
The OPEXplus digital torque wrench can measure both the torque and the angle of rotation. It covers a range of torques from 3 to 800 Nm, and it transfers the tightening results to any IT system without the need for additional control. OPEXplus torque tools are recognized in networks via the embedded Wi-Fi module.
When a tool in an assembly line is changed, the module can simply be plugged into the new screwdriver. The supplied software allows parameterization via a hotspot, the customer network or a serial interface. The intelligent OPEXplus transmits the tightening results with a tightening curve, as well as maximum torque and angle of rotation, directly to any of the user’s IT systems without the need for additional control.
Bosch Rexroth
