Rugged Control Cable has Flexible Uses
The LUTZE SILFLEX multi-conductor control cable is a rugged industrial cable ideal for stationary and flexible applications (not intended for continuous flexing use) with multiple ratings, including UL Type TC-ER or UL PLTC-ER, which eliminates the need for metal conduit and/or armor, resulting in installation and maintenance savings.
These cables are available in sizes from 20 AWG to 10 AWG with 3 to 41 unshielded or shielded conductors marked with numbers for easy identification and include a convenient ground conductor with easily identifiable green with yellow stripe insulation. The rugged outer jacket provides resistance to sunlight, oil LUTZE SILFLEX moisture penetration, making these cables suitable for wet and dry locations as well as outdoors.
