Sensor Sense: Background evaluation sensing
Jan. 11, 2007
A prior "Sensor Sense" discussed how background suppression sensors are used to distinguish between a nearby target and a wall or other reflective surface at a larger distance.
Edited by Ropert Repas
Background evaluation monitors the reflection from a background such as a floor or wall. Targets may reflect the light back to the sensor or away from it. In either case, the sensor detects the loss of the background reflection and turns on to signal that a target is present.
But the same type of sensor takes on another role with a technique known as background evaluation.
Background evaluation uses background reflection to determine the presence of the target. The light source, typically an LED, is aimed at a fixed point called the background reference. Many times the background reference is a floor or wall. The receiver has two light-detecting elements. One element senses light reflected by targets far away while the other looks for near targets.
A lens directs the reflected light to either the near or far receiver element based upon the angle at which the light is reflected. The distance between the sensor and the target determines the angle of the reflected light. Targets near the sensor reflect light at a larger angle, so the lens directs the light to the near receiver element. Since the background reference is farther away, the reflected light has a smaller angle to the receiver. The smaller angle makes the lens focus the reflected light onto the far element. A comparator in the sensor determines if more light is seen at the far or near receiver elements, and thus can determine if the reflected light is from the reference or a closer target.
Background evaluation comes into play when the target either reflects the light away from the sensor or does not reflect enough light to be monitored by the near receiver elements. When that happens, neither the far nor near receiver elements see the reflecting surface. However, background evaluation notes the loss of the far reference and thus triggers a "target present" signal even without detecting a near target.
Pepperl+Fuchs (am.pepperl-fuchs.com) provided information for this column.
March 13, 2024
March 13, 2024
Smooth Sorting with SEW-EURODRIVE!
Feb. 22, 2024
Sorting systems are essential when it comes to warehouse automation, material handling, and distribution. SEW-EURODRIVE’s automated sorting solutions increase capacity, reliability...
Setting the Agricultural Industry in Motion
Feb. 22, 2024
Agricultural products go through specialized processes of harvesting, storing, conveying, cleaning, drying, sorting, and handling to ensure that seasonal products reach the processing...
