Machinedesign 2489 Fuzzy Logic 200 800 0 0
MSD 101: Fuzzy logic
Aug. 1, 2000
Look-up tables are a convenient way to express the relationship between two variables in software
Look-up tables are a convenient way to express the relationship between two variables in software. But the interpolation required between data points can overburden a microprocessor. Rather than sacrifice execution speed, some programmers turn to fuzzy logic.
The concept goes back to the 1960s, when UC-Berkeley professor Lotfi Zadeh developed “fuzzy set theory.” In contrast to standard set theory, where objects are either in or out of a set, fuzzy sets allow objects to have partial membership. Fuzzy logic advances the concept to include mathematical operations, most notably Boolean logic.
Questions & answers
Q What’s so special about fuzzy logic?
A It gives reasonable answers despite imprecise and conflicting data.
Q How should I select membership functions?
A Six or seven overlapping membership functions spanning the output range work best. Shape is relatively unimportant.
Q Should I use it instead of PID control?
A Not if you have a system that can be modeled as a second-order linear differential equation.
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
