Machinedesign 1931 Screen Test 0 0
Fun with Fundamentals: Problem 175
Aug. 1, 2000
Screen test and Solution to Problem 174. What you see is not always what you get, as this problem by Dale W. Smith of Pomona, Calif., demonstrates.
Screen test
Problem 175 — What you see is not always what you get, as this month’s problem by Dale W. Smith of Pomona, Calif., demonstrates.
“Why, it’s my very own invention,” crowed Lucius Bluff. Most of the staff of the Lee Key Hydraulic Co. had gathered in Bluff’s office for the unveiling of his new computer-aided design software package. “You can draw your design and then access Lee Key’s catalog from this special menu. After you’ve found the right component, you press this button. The program inserts the component and begins filling out an order form.
“The highlight of the package is a powerful tool called the ‘Outer Limit’ function. Let’s say you want to draw two shapes that are similar but different sizes. You merely draw the first shape and then type in the percentage reduction or enlargement of the second shape, and the program draws it automatically. Here’s a simple demonstration.”
With a flourish, Bluff sat down at the terminal and drew a square with 6.25-in. sides. He then inscribed a circle with a circumference that touched the sides of the square. “Now for the ‘Outer Limit!’ ” A sneeze that sounded somewhat like a snicker was heard in the audience.
“I am now going to inscribe a square that is 25% smaller than the first square in the circle.” Bluff typed away and lights all over the workstation began flickering wildly. The computer generated the pictured drawing and then crashed.
Neglect line width on the drawings. How much smaller is the second square than the first? Will Bluff be working on a revision?
Technical consultant, Jack Couillard, Menasha, Wis.
Solution to last month’s problem 174 — You know how to water down statistics, if you answered 5.51 × 109 ft3.
Half of the population are women, and women weigh 75% of what men weigh for each weight category. We can then multiply the total population, 5 × 109, by (½ + 0.75/2) or, 0.875 to get the exact weight for each category.
Let X = 5 × 109 × 0.875 = 4.375 × 109 “equivalent” people.
Multiply X by the weight and percentage of population for each weight category:
(6 lb)(0.05)X = 1.31 3109 lb
(15 lb)(0.034)X = 2.23 × 109
(25 lb)(0.015)X =1.64 × 109
(43 lb)(0.034)X =6.40 × 109
(60 lb)(0.05)X =1.31 × 1010
(93 lb)(0.09)X =3.66 × 1010
(125 lb)(0.13)X =7.11 × 1010
(138 lb)(0.09)X =5.44 × 1010
(150 lb)(0.05)X =3.28 × 1010
(155 lb)(0.06)X =4.07 × 1010
(160 lb)(0.067)X =4.69 × 1010
(155 lb)(0.067)X =4.54 × 1010
(150 lb)(0.067)X =4.40 × 1010
(145 lb)(0.06)X =3.81 × 1010
(140 lb)(0.05)X =3.06 × 1010
(135 lb)(0.034)X =2.01 × 1010
(130 lb)(0.015)X =8.53 × 109
(125 lb)(0.014)X =7.66 × 109
(120 lb)(0.01)X =5.25 × 109
(115 lb)(0.008)X =4.03 × 109
(110 lb)(0.005)X =2.41 × 109
Total the weight and get 5.13 × 1011 lb. This is the weight of all humanity. Since water content is given as 67%, multiply 5.13 × 1011 by 0.67 to get 3.44 × 1011 lb for the weight of water contained in the human race.
To get the cubic footage, multiply the following:
This equates to an area approximately 14 × 14 miles by 1 ft deep. A drop in the bucket compared to the oceans and large lakes!
Contest winner — Congratulations to David Daley of Manchester, Conn., who won our June contest by having his name drawn from the 64 contestants who answered correctly out of a total of 65 for that month. A TI-68 calculator is in the mail to him.
The TI-68 Advanced Scientific Calculator by Texas Instruments can solve five simultaneous equations with real and complex coefficients and has 40 number functions that can be used in both the rectangular and polar coordinate systems. Other functions include formula programming, integration, and polynomial root finding. The calculator also features a last-equation replay function that lets you double-check your work.
Related Article
Fun with Fundamentals: Problem 174
Precision Motion Control for Robotics Systems
April 8, 2024
Learn more about Precision Motion Control for your Robotic Systems through Harmonic Drive's latest Webinar!
April 3, 2024
Introducing the Mass Flow Rate Calculator
April 3, 2024
The KNF Mass Flow Rate Calculator makes it easy to convert volume flow rate to mass flow rate. Simply enter the volume flow and the gas or gas mixture.
April 3, 2024
