The DDF-I rotary feedthrough, with integrated bus technology, can be used for connecting mechatronic gripper modules, valves, or sensors that are downstream from a rotary axis. Up to 26 electric signals are transmitted simultaneously, 13 of which are for the actuation of valves. Air and vacuum are supplied to the actuators through a fluid feedthrough and slip-ring contacts supply the tool with power, even at high speeds....
More
