How to Streamline Air Circuits
Oct. 9, 2008
Here are some tips for sizing pneumatic systems for performance and efficiency.
Who, What, Where
Authored by Michael Foy Design Engineer
Philipp Klaschka
Team Leader Air Services,
Festo Corp. Hauppauge, N.Y.
Edited by Kenneth J. Korane
[email protected]
Key points
  • Calculate flow capacity to prevent oversized valves.
  • Using different pressures to extend and retract cylinders saves energy.
  • Leaks make even the best designs subpar performers.
Resources
Festo Corp., festo.com
Monitoring pneumatics, tinyurl.com/5hxncl
Preventing leaks, tinyurl.com/6y22cn
In today’s manufacturing environments, pneumatics often provides ideals solutions for motion-control applications. Pneumatic systems are well suited for applications involving linear or rotary speeds of 4 m/sec (13 ft/sec) with forces up to 20 kN (4,500 lb). Linear actuators can come in stroke lengths as large as 10 m (33 ft) and, when coupled with a closed-loop system with a servocontroller and proportional valve, they can provide multiple speed, force, and positioning capabilities.
With the advent of fieldbus networking, pneumatic components can be simply attached to a system with less wiring and with the added capability to create centralized or decentralized valve systems.
Given the role pneumatic systems play in many industries, the question then becomes: How can manufacturing companies optimize performance and reduce energy costs associated with compressed air? The following are some important factors to consider.
Sizing valves
Sizing an air cylinder for an application is usually a straightforward process. Knowing the force and stroke requirements, and the available air pressure, engineers can readily calculate the minimum piston diameter to get the job done. When sizing a cylinder, a good rule of thumb is to initially make it large enough to provide approximately twice the calculated required force to overcome internal friction, guide friction, and other external forces.
Selecting and sizing pneumatic valves for a circuit is a bit more involved. Initial selection criteria include the type of valve and the operations it must perform; how it’s turned on and off; and whether it’s a stand-alone unit or mounted on a manifold. Beyond these basic criteria, however, flow capacity is arguably one of the most important factors. Oversized valves often lead to bigger-than-necessary connectors, tubing, and actuators, which increase the cost of components as well as the energy costs of electricity and compressed air — while undersized valves hurt system performance.
Flow capacity indicates the amount of resistance a valve presents to a pneumatic circuit, and is typically measured as volume coefficient (Cv) or in liters per minute. All devices that conduct air resist flow to some degree, and pressure drop across a device will increase with flow.
In the past, common practice was to match the port size of the valve with the port size of the actuators. Experts no longer recommend this method because today’s valves are smaller yet have greater flow capacity than their counterparts of a few years ago. Smaller valves tend to switch quicker, cost less, and consume less power.
Thus, the first step in selecting a valve means calculating the flow required to move an actuator within an allotted time. The following equation lets you calculate the flow coefficient required for the valve. For U.S. units, flow rate is defined as:
and for SI units,
The compression factor Cf is defined as
Then determine the required Cv. For U.S. units,
For SI units,
As an example, consider a double-acting cylinder with a 25-mm bore and 100-mm stroke. Rod diameter is 10 mm, air pressure is 6 bar, and pressure drop across the valve is 0.25 bar. The application requires the cylinder to extend in 0.25 sec and return in 0.2 sec.
The goal is to determine the necessary valve Cv. First calculate areas and volumes on the extend side of the cylinder.
Areas and volumes on the retract side are:
Second, calculate the compression factor,
Third, calculate the flow rate required to extend and retract the cylinder.
Finally, calculate the Cv necessary to extend
For this example, the valve must have at least a Cv = 0.158 for the extend stroke and Cv = 0.166 to retract within the system’s time requirements. A valve with the exact specific flows for both extend and retract most likely does not exist, so select a valve with a larger Cv. One with a Cv = 0.200 should suffice. A slightly larger valve also takes into account restrictions caused by fittings and tubing which can affect reaction time.
Note that any device, fitting, or run of tubing can affect the system flow rate. In time-critical applications, a few extra inches of tubing or the wrong fitting can mean the difference between a circuit that works and one that does not. For this reason, valve ratings alone cannot predict flow rates through a system branch.
Regulating pressure
The pneumatic energy used to perform a task is a function of pressure and volume. In typical pneumatic systems, volume equals cylinder volume plus the volume of the pipe between the valve and cylinder. These volumes are typically pressurized and emptied each time a cylinder extends or retracts. The combined cylinder and pipe volumes should ideally only be charged to the pressure required to successfully stroke the cylinder. Exceeding this pressure wastes energy, and it is easy to both calculate the correct pressure and reduce overpressure.
NOMENCLATURE
d = Cylinder diameter, mm or in.
dr = Rod diameter, mm or in.
G = Specific gravity (1.0 for air)
L = Stroke, mm or in.
Pa = Atmospheric pressure, 14.7 psi or 1 bar
P1 = Inlet pressure, psi or bar
P2 = Outlet pressure, psi or bar
Q = Flow rate, ft3/min or liter/sec
T = Temperature, Rankine or Kelvin
t = Time, sec
te = Cylinder extend time, sec
tr = Cylinder retract time, sec
V = Volume, in.3 or liter
P = Pressure drop across valve, psi or bar
In many applications there is a significant difference between the cylinder force needed to extend (push a load) versus retract (pull a load). It does not matter which force is larger; the point is, there is usually a big difference between the two. The vast majority of pneumatic controls, however, apply the same pressure for both extend and retract strokes. In addition to wasting energy, charging a cylinder to a higher-than-necessary pressure increases noise, vibration, and leakage and, therefore, lowers mean time between failure (MTBF). Higher pressures also reduce cylinder speed, because the cylinder wastes time charging beyond the level required, and it takes longer to empty the chamber. And overpressurizing magnifies internal and external leaks.
To illustrate the problem, let’s estimate how much energy used to compress air is wasted by pressurizing cylinders beyond the levels necessary to stroke a cylinder. Assume that the cylinder is sized correctly for the push load, but only half the pressure is needed to retract the cylinder. With a 2:1 ratio of loaded versus unloaded cylinder stroke, about 20% of total energy is wasted if the cylinder operates at the same pressure for push/pull loads.
In the cylinder in the above example, reducing pressure on the return stroke from 6 to 3 bar would reduce compressed- air consumption on the return stroke by nearly half. For a setup operating on an 8-hr shift year round, resulting savings could be well over $100/yr for a single cylinder, paying for a regulator in a matter of months.
Many practical, low-cost components can control individual cylinder pressure and help eliminate energy waste. On subbase-mounted valves, for example, sandwich pressure regulators independently control a cylinder’s load and nonload pressure.
Elbow pressure regulators provide another easy and low-cost solution. These compact devices look like elbow flow-control valves, but they control pressure. The regulators have a built-in check valve for reverse flow and a dial to indicate pressure settings.
Minimizing volume
The development of decentralized fieldbuses for pneumatic- valve manifolds lets designers reduce the distance between valve and cylinders. This reduces pipe volume. In fact, from an efficiency standpoint, the ideal place to mount a valve is directly on the cylinder and completely eliminate the piping.
Reducing pipe volume between the valve and cylinder saves energy even if pipe volume increases between the compressor and valve manifold. That is because the volume between valve and cylinder pressurizes and empties every cycle, whereas the volume between the compressor and manifold rarely empties.
Some bus protocols, such as AS-Interface, permit a simple, low-cost serial link to a single valve. This lets designers mount valves on the cylinder, considerably reducing air consumption.
System considerations
Smaller cylinders and valves require less space, save money, and consume less air. But keep in mind that valves and cylinders are only one part of a complete system — every component that potentially causes a flow restriction or delay must be considered as part of the overall design. Here are some additional factors to consider.
Cylinder and valve ports can restrict airflow due to the fitting’s internal orifices. Flow controls can restrict airflow even in their full-open position. And 90° fittings cause pressure drops and add delays.
Make air lines between the valve and cylinder as straight as possible with minimal bends. And keep in mind air lines have different flow characteristics depending on whether they are rigid pipe or flexible tubing. Each application has an optimum air-line ID. Increasing the air-line diameter increases Cv but also increases the volume that must be filled and emptied each cycle.
For actuators, select cylinder bore sizes to handle the expected load plus a reasonable safety factor. Larger-thannecessary cylinders cost more, waste energy, and add cycle time. Likewise, cylinder stroke should be no more than required. Longer-stroke cylinders are also more expensive, waste energy, and add cycle time.
In general, components with the smallest Cvs and largest pressure drops limit circuit performance the most. Increase these Cvs first to have the greatest impact on circuit performance. Similarly, components with the largest Cvs and smallest pressure drops are possibly oversized. Decreasing these Cvs could improve circuit performance.
Simple, rugged, and economical pneumatics is well suited to many manufacturing processes, such as this brewery packaging line. Keys to improving performance include matching valves and actuators, using only the pressure required, keeping systems compact, and eliminating leaks.
Modern pneumatic servodrives offer multiple positioning and other advanced capabilities. This Festo VPWP proportional valve has pressure sensors that report diagnostic data to the controller, letting it monitor the condition of servopneumatic drives.
Cylinders should be sized to handle design loads plus a safety factor, without oversizing that can waste energy and increase cycle time. Among new designs for pick-and-place and positioning systems, the DGSL mini slide features an integrated bearing system and 0.01-mm accuracy.
