Rotorflow Sensor Monitors Fluid Flow from 0.1 to 12 gpm
RotorFlow sensor from Gem Sensors monitors fluid flow from 0.1 to 12 gpm
Access our Reader Service Web site to quickly find and request information on products and services found in the pages of Machine Design.
www.machinedesign.com/rsc
The RotorFlow transducer from Gems Sensors & Controls, Plainville, Conn. (www.gemssensors.com), constantly measures fluid flow using a static Hall-effect sensor. A magnetic rotor attached to the paddle wheel spins at a rate proportional to flow. The rotor’s spinning magnetic field causes the Hall sensor to generate a series of voltage pulses with a frequency proportional to flow rate. This frequency is converted to an output signal. And the voltage of these signals can range from 4.5 to 24 Vdc.
Inlet and outlet ports range in size from 0.25 to 1.0 in., with flow rates going from 0.1 to 60 gpm. Lower flow rates require an optional low-flow adapter. Accuracy is typically within 7%. Brass and stainless-steel bodies withstand temperatures to 212°F and pressures to 200 psig at 70°F; polypropylene bodies handle temperatures to 180°F and pressures to 100 psig at 70°F. For convenience, the paddlewheel is colored orange, letting users visually verify that liquid is flowing.
© 2011 Penton Media, Inc.
