Only some secondary machining operations are needed on the molded versions, says their manufacturer Aries Electronics Inc., Frenchtown, N.J. ( This drastically reduces the price of the test sockets, claims Aries. The sockets mount and detach from burn-in boards via solderless pressure-mount compression spring probes. A springloaded, cam-actuated pressure pad holds ICs during tests.
